Old 03-16-2010, 08:41 PM   #1
Ford 5.8 engine help (1995)-need to ID part
I broke a bolt off trying to remove a part today. I haven't seriously worked on a car since high school and I'd appreciate some help identifying parts (Haynes is worthless and shop manuals are still in transit from ebay).
The bolt I broke is one of the two you see on the attached pic. On either side of the green antifreeze. I'm hoping the thermostat is under there. What is the name of the part the bolt goes into? The coolant manifold? (not my pic-got it off internet)
http://www.autoclinix.com/Ford/Pic4%20%28labels%29.jpg
Any advances in broken bolt removal in the last 20 years? I am soaking with a solvent tonight. Try and remove with a bolt removal bit? Drill out? Tap a new hole next to the hole and just use that?
Any advice is good advice.
Tom
Tom
Austin, Texas
1995 SMB E250
bluedog225 is offline   Reply With Quote
Old 03-16-2010, 09:25 PM   #2
Re: Ford 5.8 engine help (1995)-need to ID part
Tapping is not an option- nothing will ever fit back right and it might not be mated- speaking of which be careful not to destroy the surface of either piece where they fit together.
If the head broke off, can you not remove the other bolt, then the cover, then have the shaft to work with instead of drilling? That would probably be the route I would take, even to the point of destroying the cover, as that is probably easier to replace.
Incidentally, consider a tow to a mechanic... it might be less expensive in the long run.
Old 03-16-2010, 09:44 PM   #3
Thanks. It broke off pretty deep. I got the other bolt to move and am letting it soak some more before I attempt to finish removal.
I've got the think partially taken apart. Already replaced the plugs, wires, distributor, cap, and taken out the heater core (it was leaking). It's a mess to hand off to a mechanic. And I bet it would be pretty pricey.
The van is a 1995 with 100k. In addition to fixing the heater core, I am performing some "routine" maintenance. I figured, why not the thermostat and possibly the water pump, since I am in there already.
Any thoughts on how a pro would remove the bolt shaft?
Tom
Tom
Austin, Texas
1995 SMB E250
Old 03-16-2010, 10:12 PM   #4
I think the name of that part is actually the thermostat housing. And yes, I have have broken off that bolt too!
We drilled out the center of the bolt, the used a bolt extractor bit (aka easy-out). Pretty sure they've been doing it this way for a long time. Also, take a punch or a rod, and give the broken bolt a good hard smack to break it loose.
Old 03-17-2010, 09:48 AM   #5
scatter's Avatar
I agree with everything said above. Be careful when using the easy-out. They are made of hardened steel (like a drill bit) and with too much pressure they will break. If it breaks down in the bolt where you drilled the hole, the party's over. Can't be drilled out as it's too hard. If you have a torch, even a propane one, you can apply heat to the block where the bolt threads are. The expansion from the heat will help loosen it up. That along with lots of solvent and the aforementioned smack with a punch should do it. Just don't break off that easy-out. Doing that pretty much reduces your options to zero....
Scatter
2007 RB50, 6.0
K1WGB
Old 03-17-2010, 03:42 PM   #6
I've been working on this all day. Just saw this. Good advice about the EZ out. I broke it off about 10:30. Been trying to drill into the back of it since then. Demoralized. Even the diamond dremel didn't work.
Think the shop can work a miracle or is it really bad news. The drills are barely touching it.
Tom
Austin, Texas
1995 SMB E250
Old 03-17-2010, 04:46 PM   #7
Is there any of the old bolt sticking out after you removed the t-stat housing?
If there is, you may be able to weld a bolt onto it and use that to unscrew it.
If not, you probably will have to remove the manifold or whatever it bolts into and head to a machine shop. A good carbide cutter will go into the ez-out, but everything must be held solid - no hand drilling allowed. Using a left hand cutter (drill bit or endmill) will probably catch the bolt and unscrew it after you get in 1/2" or so.
Possibly (not likely) you may be able to remove the radiator, water pump and anything else that might be in the way and use a magnetic drill to drill the bolt out in place. Locate the mag drill on the front of the block and drill it out as above, but in place.
I'll bet on the machine shop.
Old 03-17-2010, 07:16 PM   #8
bettyford's Avatar
Send a message via MSN to bettyford
I have used reversed drill bits on Harley Davidson heads in the past and they work great. either way your shop would be able to do it just be careful not to bugger it up to bad.
Good luck
Ron
Going where most dont
"one day at a time"
bettyford is offline   Reply With Quote
Old 03-18-2010, 01:24 AM   #9
For that kind of task, I have found Cobalt drill bits (NAPA) to be especially effective.
Old 03-18-2010, 06:08 PM   #10
Is this the upper passenger-side bolt or the lower driver-side bolt?
If you absolutely can not get the bolt out, it would be worth looking into having a mobile welder come out and help deal with it. You can grind out the aluminum in a V to expose the bolt, which can then be pulled out. The area can then be built back up with aluminum and tapped. This would be fairly easy with the upper bolt, but the lower bolt will be more of a challenge. This process would certainly beat having to pull the lower manifold, which requires removing the upper intake & throttle body, fuel rail, plug wires and distributor, vacuum lines, coil, etc. Doable, but not the best way to spend a weekend.
If you do end up pulling the manifold, I would just replace it.
Good luck!
Dave
Davelength is offline   Reply With Quote
