Old 04-21-2014, 04:47 PM   #1
panion's Avatar
SOLD 2000 Chinook Diesel For Sale SOLD
Price reduced.... A lot 29,500
Hey guys, I used to own the manfort (sportsmobile) and sold it to a guy in Germany. After bouncing through a couple of RV's I'm now selling my Chinook. It's one of the few diesels out there and I thought I might see if any one here was interested. Convert it to 4x4 and you would have a very luxurious package for getting off the beaten path.
Here are the specs and some pics. I'm asking $32,500, it has 108,000 miles on it. It's very reliable, I would drive it to Alaska tomorrow without worry.
Tom.
2000 Chinook Concourse Features
Excellent condition, everything working as it should. Notice all of the extras including 22” LCD TV, Bike Rack, Swing out tire rack, inverter, solar system, two powered fans, touchscreen navigation stereo system, and more.
This is a unique Chinook in that it has the diesel engine and many upgrades. The other Chinooks (V-10) get 9 to 11mpg. This one can average 15mpg with plenty of power.
Contact: tok2tom@gmail
Comfort and Livability
Front and side overhead storage space with interior lighting
Expanded rear wardrobe
Total interior/exterior storage space of 102 cubic feet
Deluxe reclining driver and passenger captain chairs with lumbar support
6-way power driver/passenger seat base
One-piece wall-to-wall carpet with high-density urethane pad (including driver compartment)
Cab area privacy drape
Day/night fabric shades
Decorative hardwood valances with indirect lighting
Fold-down sofa bed with under bed storage
Deluxe hardwood cabinetry with raised-panel doors
Overhead fluorescent lighting
Kitchen Features
3-way (110/12V/LPG) double-door 6' flush-mount refrigerator
3-burner propane cooktop
Recirculating power range-hood with light
Larger Corian counter top with double sinks
Single handle faucet with water filter
Flush-mount sink covers
Slide out cutting board
Three hardwood drawers with deluxe roller slides
Glass mirror on pantry door
Tip-out sink storage
Bathroom
Recessed sink
Marine-style china toilet
Power roof vent fantastic fan
Recessed medicine cabinet
Water-saver chrome shower head
Shower curtain
Raised-panel hardwood bathroom door
Two robe hooks on bathroom door
Fiberglass shower
Convenience and Safety
Lighted entrance grab-handle
Entrance door with window, screen door, and deadbolt lock
Fire extinguisher
Smoke detector
LP gas detector
Hardwood magazine rack
MagLite flashlight with brackets
Towel racks
Three double coat hooks (one inside closet)
Paper-towel holder
Hardwood note pad holder
Exterior
Heights, Weights, & Dimensions:
Exterior length 21'
Exterior width 7'7"
Exterior height: W/roof air 9'11"
Interior height 6'5"
Gross vehicle wt. 10,700
Dry weight approximate 8,800
Wet weight approximate 9,500
Gross comb. Wt: Veh. & trlr.com 18,700
Wheel base 138"
Bed Dimensions:
Sofa Sleeper 72" x 48"
Dinette 68 " x 36"
Ford Chassis
7.3 liter V8 Diesel engine
4-speed automatic transmission with overdrive
Power steering
4-wheel, antilock disc brakes
Dual rear wheels
Tilt wheel/cruise control
Power windows
Power door locks
Heavy-duty, 130 Amp alternator
In-dash air conditioner
37-gallon fuel tank
Driver and passenger side airbags
Engine block heater
4.10 limited-slip rear axle
AM/FM CD double din touchscreen navigation sound system
138" wheel base: provides excellent driving
Super duty E-350 chassis
Twin I beam front suspension system
LT 225-75 R16 E rated all season radial tires
Exterior Body
One-piece fiberglass body, fully reinforced
Arctic foam insulation
Double laminated fiberglass inner roof liner with foam insulation
Thermopane windows with screens
Swing out spare tire carrier (custom)
Side & rear lockable outside storage compartments all keyed the same
Exterior base coat, clear coat, 2-color custom paint graphics
Chrome rear bumper with step
Sewer hose storage compartment with hose
Aluminum roof rack & ladder
Rear & side porch lights
Lighted dump valves
Insulated solid floor laminated to body
Exterior cable TV/telephone jack
Powder-coated exterior brackets
Heating/Cooling/Power and Water Systems
5-way systems monitoring panel
32 gal. Fresh water tank
Pressurized city water hookup
19 gal. LPG frame mount tank
Roof A/C with Heat Pump and Thermostat
Two heavy-duty, deep cycle auxiliary batteries, 200 amperes of 12V power
Deluxe slide-out battery tray
6-gallon propane hot water heater
Exterior G.F.C.I. receptacle
Power, Fantastic Fan roof vent with thermostat/rain sensor and an additional Maxxair fan
16,000 BTU propane furnace with auto-ignition
23 ft. service cord
Self-priming water pump upgraded to variable speed
Dual holding tanks: 35 gal. gray/15 gal. black
120V/12V power center, 45 AMP converter/charger with automatic transfer switch
Auxiliary battery disconnect switch
Bi-directional charging system
Low-voltage coach disconnect with audible alarm
Emergency start switch
Installed Options
4.0 generator with remote start switches and hour meter
13,500 BTU roof air with heat pump
Awning with crank
3-burner cooktop with oven
Microwave oven
7.3 liter Power Stroke Turbo Diesel
Rear back-up camera
12V heated holding tanks
Samsung LED 22” TV with remote
Microwave oven
Corian counter tops with back splash guards
Fiberglass running boards with flares
Stainless steel wheel liners
Mud flaps with stainless steel accents
Solar System
Trailer hitch, 5000 lb. towing capacity
Remote heated deluxe side mirrors
High-gloss wood grain dash décor package
Outside shower
6-way power driver seat base
Adjustable, amplified TV antenna with power booster
Black tank flush kit
Hidden Safe
Bike Rack
Sewer Connection Upgrade
1000 watt Pure Sine Wave Integrated Inverter
Media Center for Movies and Netflix on the road
Tuned for Performance and Mileage
4” Exhaust from the Turbo back
Sliding Closet Rod
Lifted Swing out Spare Tire Rack
Upgraded Speakers (kenwood)
Alpine Amplifier and Subwoofer
Front Receiver Hitch
Black Tank Vent Tube Fix Taken Care of (common Chinook problem)
More pictures and info on request.
2001 RB 7.3 Powerstroke 4WD.
https://sportsmobile4x4.blogspot.com/
panion is offline   Reply With Quote
Old 04-21-2014, 05:15 PM   #2
Re: 2000 Chinook Diesel For Sale
Nice! I have looked for one on and off but now is not the time for me. Anyway, it should sell quickly.
Good luck and nice rig.
Old 04-21-2014, 05:48 PM   #3
A Chinook isn't in the immediate future for me... but I'm very curious about that bike rack. what kind is it ??
Very cool rig BTW. Should sell without any problems.
Steve W
SteveW is offline   Reply With Quote
Old 04-21-2014, 06:19 PM   #4
panion's Avatar
I had to make my own bike rack. I couldn't find a good solution with the rear entry.
Old 04-22-2014, 01:10 AM   #5
schluchtenflitzer's Avatar
I hope it is OK if i write this here.
I bought manfort from "Panion". A deal with a lot of risk for me as i had no chance to check the van (just on pictures).
I have to say that Tom is a very friendly, reliable, trustable good guy who maintanance his vehicles very well. And he helped me a lot with all the things need to be done before shipping to europe. He helped me like we are friends for years!
I never had regret the deal for one second. Thanks again for all Tom!
BTW i also love the Chinook and i am sure it will be sold soon.
Dietmar
www.Dieda-unterwegs.net
Old 04-22-2014, 08:25 AM   #6
Stole this picture of a Chinook with Ujoint 4 inch 4x4 conversion just in case anyone was wondering if it could be done. Agile could convert it as well. I have been waiting for someone to convert a diesel chinook but I am only aware of a couple of diesels coming up for sale over the last year. The Chinook in the picture below has the V-10.
catmandu is offline   Reply With Quote
Old 05-05-2014, 02:29 PM   #7
He added some more information:
More pictures Link: https://www.dropbox.com/sh/2dcq0p2813q7 ... 1-/Chinook
Exterior Video Link:
Interior Video Link:
Pow Patrol
smb50co
Hooch
Hoooch
